Flanges for penstocks
Hi friends!
Would u help me?
I'm checking calculation for a pair of flanges stated for two specific penstocks.
I'm following the directions of ASME BPV code sec VIII app. 2, and I found the first flange (Welding neck, integral, 900mm dia. 429 psi) to be conform.
My problem is the other flange, 1800mm dia, ring type,220 psi (Optional as shown in fig 2-4 (11)), cause I found stresses too high... May be this is not the right code to check by... do you know another applicable code in this case?
Thanks a lot for your help.
Heyner.
RE: Flanges for penstocks
Hey! not everybody at once!
Heyner,
Have you checked American Water Works Assn code AWWA C207 for large pipelines usually encountered in water transmission.
nrp12345
