Spacing between PEM fasteners
can anyone assist me with a calculation or formula to work out the distance between M4 PEM fasteners whilst using 2mm mild steel sheet to give maximum strength but minimal weight.
Cheers
Cheers
RE: Spacing between PEM fasteners
I always used a "rule-of-thumb" of 1.5 - 2.0 times the screw diameter, depending on the material, for wall thickness. In the 2mm steel you should be OK with the 1.5d You should always test out your calculations before putting them into use. You can get more info about the entire joint design and its safety factors at www.boltcalc.com
Good Luck
Bill P.
CSFT, Inc.
