Etchants for 440C Stainless
I am looking for a etchant that will show the retained austinite in 440C stainless steel. Would anyone know a reliable one?
RE: Etchants for 440C Stainless
ASTM E407, Standard test method for microetching metals and alloys should have something you can use.
If you cannot get hold of a copy I will have a look and see what I can find.
     Bruv
The most common etchant for 440C is Vilella's reagent (nitric-hydrochloric). A note of caution regarding visually evaluating retained austenite, unless the levels are fairly high 15+%, it maybe difficult to see and evaluate.  Typically, retained austenite is tested by x ray diffraction, in order to accurately determine the volume present.  Hope this helps.
