Valve Stem made of Cast Bronze
Can we use cast Bronze as a stem material or is the Forged type is the mostly preferred ?
The valve is an angle Globe valve used as a fire hydrant. The service is Sea or Raw water at normal conditions. The valve Body is made of ASTM B150 C63200 Cast Bronze.
RE: Valve Stem made of Cast Bronze
Have you considered the axial forces & bending forces on the stem? Depending on the total pressure acting on the disc,your stem should be able to withstand the load safely.
calculate the stem dia. wrt the ultimate tensile or compressive value for the material you intend to use as the stem material.I suggest you to consider giving all the details to a good valve design engineer before deciding on anything drastic.
Bye!
