240V lighting verses 115V lighting
Can any one tell me if there are any advantages of using 240V lighting circuits over 115V lighting circuits? Any comments would be gratefully received.
RE: 240V lighting verses 115V lighting
As for 240V verses 120 V, assuming it's a single phase supply the only advantage I can see is one can put more luminaires on the same feeder circuit. 240v lighting is usually used for longer runs e.g.: parking lots, park lighting, some street lighting, sports lighting, factory lighting, wall packs. It is usually not used for areas where a 3 phase voltage supply is available.
If you used a 120/240V lighting supply on a similar 240V run if one leg trips you would still have half of the lights on.
Ray Micallef, P. Eng.
Power Generation/Utility Industry
