Microscopes with parallel lines
Is anyone aware of an inspection system which would allow one to have two parallel lines of measurement instead of the traditional crosshair of X /Y plane. I want to have one line as a baseline or zero point and be able to set the other line a particular distance away - and inspect if all the points I need to measure are in between somewhere.
This technique also needs to be fairly ergonomically compliant as an operator will be looking in between these two lines for up to 10 hours!
Can anyone help?
Emer
Can anyone help?
Emer
RE: Microscopes with parallel lines
In precise levelling we usually stick to about 50-70m sightings.
They have a whole section on microscope target optics, including parallel line measurement systems. Prices are reasonable.
Kevin VanZuilen "KevinVZ"
