pcb hole diameter
pcb hole diameter
I'm looking for specification for pcb hole diameter to hand solder 18 ga. magnet wire that carries 300 volts 30 amp peak in our motor. Can you help with this?
Jim
Jim
RE: pcb hole diameter
Foxfur
It also states that the maximum allowable nominal current for 18 ga is 7 amps and that the wire will fuse at 83 amps. I think you should consider this in your design.
Only the current and wire R have to be taken into consideration, V is irrelevant.
<nbucska@pcperipherals.com>
