How old a WPQ to Accept?
I have a contractor submitting WPQ for his welders dated 1994,'97,'98,and '99. Spec is b31.3 gmaw for astm a53 pipe line work. I think this is to old a WPQ and I should request new. Any industry guidelines, Thanks
RE: How old a WPQ to Accept?
Have a nice day
Gerald Austin
Iuka, Mississippi
http://www.weldinginspectionsvcs.com
One other thing is though the code itself is silent, some client specifications specify that only joints with some NDE can be used for maintaining continuity, hence if a fillet weld/ bridge tack data presented for extending continuity, it would not be acceptable as per those specs.
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
End of all knowledge is the attainment of immortality!
as per asme section ix. check his welding( welding process) continuity log, within six month period, if he has not welded with a process which he has qualified already , then requalification is required
