Adding collar (upset) to existing shaft
Looking at putting a collar on a 9" diameter shaft to resist thrust bearing forces, rather than machine from a 12" bar - this would also be used to upgrade old shafts to the new design.
I'm thinking of using a tight interference fit (r6 range) with 3 equally spaced plug welds.
Comments? Anyone done this before? Any better suggestions?
Thanks!
Thanks!
Keep the wheels on the ground
Bob
showshine@aol.com
RE: Adding collar (upset) to existing shaft
Bob
showshine@aol.com
You might just want to add enough stock
to put a taper on the shaft to lock a collar
in position.
Cheers
Greg Locock
http://www.loctite.com/pdf/retaining.pdf
Looks like the interference fit w/ loctite might be a good compromise
Bob
showshine@aol.com
