Re- Determining appropriate text height in model space
Fellows,
I appreciate the inputs you have made so far on this issue. I have gathered quite a lot. However, the explanation so far has been mostly based on printing done in 'model space'
The following are for clarifications:
DRAWING
1.After creating the geometry in model space, 1:1, how do I size the text to match with the 1:1 drawing, so that I don't under or over size.Is there a formular wrt the drawing?
PRINTING
2.How do I adjust the text height so that the standard is still maintained regardless of what paper size (A0-A4)I'm making the final print out in.
Note: I draw in model space and print in paper space.
Thanks.
Sammysparkle!
DRAWING
PRINTING
Thanks.
Sammysparkle!
RE: Re- Determining appropriate text height in model space
Flores
