projected area V5R9
projected area V5R9
hi everybody,
what is the best way to make projected area from a solid?
is there any direct command in catia V5R9?
thank you,
vakantanka
thank you,
vakantanka
RE: projected area V5R9
if u have the knowledge Advisor License u can use the Parameter "smartWetarea" Available in Formulae to get the Projected Area of the Solid.
Else the best i can think of is use the EXTRACT Command in GSD with Point Continuity Option to get a single surface of ur Body and use the Measure Icon to get the Surface area of the Extract. this will be equal to the solid projected area.
hope this helps
Ganesh.n
Cheers
Ganesh.N
ganesh.n@engg.tjc.co.in
