VB programming for printing formatted text
RE: VB programming for printing formatted text
I program often in VB 6.0 but I have never seen a direct VB utility for printing formatted text.  You need the VB reports module; I'm sure it is available in the Enterprise Visual Studio but I don't have the reports module.  The reports module is VB's method for sending stuff to the printer.
Here is a sample that I have pulled directly from a program that I wrote a while back. I have not altered the sub in any way. It should give you an idea on how to print.
Note: cdOne is the common dialog control...
Private Sub cmdPrint_Click()
    Dim i As Integer
    Dim count As Integer
    Dim searchedFrom As String
    Dim searchedTo As String
    Dim defaultPrinter As String
    'diable the print button
    cmdPrint.Enabled = False
    searchedFrom = CStr(dtpFrom.Month) + "/" + CStr(dtpFrom.Day) + "/" + CStr(dtpFrom.Year)
    searchedTo = CStr(dtpTo.Month) + "/" + CStr(dtpTo.Day) + "/" + CStr(dtpTo.Year)
    count = lsvResults.ListItems.count
    'have the printer dialog come up and allow the user to pick a default printer
    Const ErrCancel = 32755
    cdOne.CancelError = True
    On Error GoTo errorPrinter
    cdOne.Flags = 64
    'see the Help on Flags Properties (Print
    '     Dialog)
    cdOne.PrinterDefault = True
    cdOne.ShowPrinter
    MsgBox "Printing....", vbInformation, "Print"
    mouseWait 'show the hourglass to indicate that it may take a while
    Printer.FontName = "Arial"
    Printer.FontBold = True
    Printer.FontSize = 7
    Printer.Print "Printed on: " + Format$(Now, "dddd, mmm dd, yyyy hh:mm AM/PM")
    Printer.Print "Search String: " + cmbSearch.Text
    If chkDate.Value = vbChecked Then 'then print the date range, otherwise do not
        Printer.Print "Date Range: " + searchedFrom + " To " + searchedTo
    Else
        Printer.Print "Date Range: All Available Alarm Files "
    End If
    Printer.FontBold = False
    Printer.FontSize = 7.5
    Printer.Print " "
    Printer.Print "MM DD YY"
    Printer.FontSize = 10
For i = 1 To count
    Printer.Print lsvResults.ListItems(i).Text  'this may start at zero and may need to be changed
    If i Mod 60 = 0 Then 'start a new page
        Printer.Print " "
        Printer.Print " "
        Printer.Print "        Page " + Format(Printer.Page, "#,###")
        Printer.NewPage
        Printer.Print "Printed on: " + Format$(Now, "dddd, mmm dd, yyyy hh:mm AM/PM") '+ "        Page " + Format(Printer.Page, "#,###")
        Else
        End If
        Printer.Print " "
    End If
Next i
Dim numLinesDown As Integer 'the number of lines to drop the page number down
Dim numLinesToAdd As Integer 'number of lines to add to the last page to get the page number in the right spot
numLinesDown = count - (60 * (Printer.Page - 1))
numLinesToAdd = 63 - numLinesDown
For i = 1 To numLinesToAdd - 1
    Printer.Print " "
Next i
Printer.EndDoc
mouseUnWait
cmdPrint.Enabled = True
Exit Sub 'exit to avoid error handler......
errorPrinter:
    If Err.Number = ErrCancel Then
        Exit Sub
    End If
    Resume
End Sub
Troy Williams
fenris@hotmail.com
I am a recent Mining Engineering Graduate with an interest in Genetic Algorithms, Engineering and Computers and Programming. I also have an interest in mineral economics
Troy
Thanx for the sample code, I had managed to print formatted text,
however I am not very comfortable to print scientific equation very
easily. Normally what I do is first write the output file from the
program and then readline and print. I am still improvising it.
Please visit my website http://www.narendranath.itgo.com/mysoftware.html
and download the "Stokes"  program written in VB and advise any comments
or suggestions.
Narendranath R
narenr@narendranath.itgo.com
Pipeline engineering is made easy with state of the art computer software, visit www.narendranath.itgo.com.
I will check out your software, but as far as scientific equations go. I don't think that it is easy. What I have seen mathematica do is output the equations as images (jpg,bmp,etc.).This might be of some use. Unfortunately I little experience with generating graphics.
You might also try using exotic fonts, they may at least allow you to reproduce some of the mathematical notations..
Good Luck
Troy Williams
fenris@hotmail.com
