Question on welding stainless to carbon steel
My first time post and I need the weld spec for stainless to carbon. I'm the mechanical superintendent for a water/waste water company. The process we are using is
GTAW with 309 filler. The engineering firm who supports us
stated they have never seen this done. I am aware this is the proper procedure, I would just like the procedure in hand to better present my case. Any help would be appreciated. My e-mail is dharper10@cox.net.
Thank you
Dennis Harper
RE: Question on welding stainless to carbon steel
See my post in Thread725-107465 "Welding Stainless Steel 316 to Carbon Steel." I posted a procedure for P-1 to P-8 with GTAW.
Hugh
You may use filler as ijzer's comment. However, please also consider the application of carbon steel at such service temperature.
Carbon steel maximum operation temperature
Thread330-98003
If it is butt joint welding , it is better to complete weld with ER NiCr-3
