Did I disable my quick keys?...How do I fix?
Aargh, I can't use my quick key's, how did I disable them?
How can I turn them back on? I hit "z" enter, & it say's "Unknown command "Z" ".....Thanks soo much in advance.
TYSON
RE: Did I disable my quick keys?...How do I fix?
If so, check if your ACAD.PGP still exists. Should be in the "support" folder of AutoCAD.
If that's there, check your search path in AutoCAD under options. Make the "support" folder in the path.
Let me know if otherwise.
I was going crazy...
