propane mixing temperature
now i have 135*F therm.off the coolant exit of the converters /would it be beneficial to use colder therm.to get the coldest charge possible /do you think lowering the temp of the gas at the exit of the converter before mixing to the 425 would help making more power
RE: propane mixing temperature
Tomy:
Lowering the fuel temp to increase the air charge density will work, and work best in the 70 deg F range.  Colder than that and you run the risk of getting liquid droplet mist into the air stream with irregular cylinder air-fuel distribution.
The primary benefit to lowering the temperature is not the air charge (although that is a positive benefit) but that you reduce the formation and accumulation of hydrocarbon heavy ends, semi-solids, and paraffin’s.  They tend to form at temperatures of 140 deg f.  Some severe cases have resulted in vaporizer stoppage in as little as 30 hours of operation.
Franz
