Cyclohexylamine - safety measures
Can anyone give me more specific information about the hazards with cyclohexylamine? Specifically I would like to know about the safety measures for preventing explosion risks and human protection.
With a small vessel, containing apr. 2 cbm of Cyclohexylamine and only a small dosing pump and some 30 m piping, what should one consider?
RE: Cyclohexylamine - safety measures
https://fscimage.fishersci.com/msds/97156.htm
Second, what concentration are you dealing with?
Obviously, more safety precautions are necessary for higher concentrations. Due to OSHA & EPA and UFC (fire code) requirements, you may need secondary containment, ventilation, a sprinkler system, emergency spill equipment & PPE (personal protective equipment). However, on the EPA's 'List of Lists,' the RQs for cyclohexylamine, CAS# 108-91-8, are 10,000 and 15,000 pounds, and you are far below this (so you are not considered a major threat). http://www.epa.gov/ceppo/pubs/title3.pdf
In any case, you should discuss this with your local regulatory agencies.
From the MSDS, the vapor is heavier than air and has an explosive range 1.5 to 9.5%, and the TWA is only 10 ppm, so good ventilation and PPE are probably the very minimum requirements.
Besides, it's good to remember that the flash point in air is 28.5oC, and toxic nitrogen oxides are produced on an exothermic and rapid combustion reaction.
There have been two terrible explosions involving hydroxylamine iver the last few years. It seems to be a very unstable chemical.
Cheers,
John.
