Is this possible in AutoCAD? Pls, help!
Hello all!
Can anyone hint me on how to write superscript in AutoCAD. For example, how do I write squared metre in CAD. Your contri will be appreciated.
Cheers!
Sammysparkle!
Cheers!
Sammysparkle!
RE: Is this possible in AutoCAD? Pls, help!
I would use MTEXT.
Type in the dialog box ...
(for example)
box2/
Highlight "2/"
The "a/b" icon should NOW be selectable.
The text should now appear "superscript" w/ an underline.
box-
It's the only thing I can think of ... sorry.
Another way might be to insert a symbol but that requires findind a FONT (TTF) that has superscripts as symbols.
Later Guy.
type in the meters say 3...use the mtext command...
"3 2^_"... this is 3(space)2(carat)...
edit it...highlight the 2 and the carat...
then the text looks like 3 ²...backspace the ²...
then it looks like this 3²
you rock
Except you don't need the space ....
"32^" ... 3(no space)2(carat)...
highlight 2^
and select "a/b" icon .....
Here's a star!
rKeyTek and dskiver, you are wonderful! You've made my day.
Cheers and don't stop kicking.
Sammysparkle.
Alt 171 = ½
Alt 172 = ¼
Alt 253 = ²
Alt 0169 = ©
Alt 0176 = °
Alt 0177 = ±
Alt 0178 = ²
Alt 0179 = ³
Alt 0188 = ¼
Alt 0189 = ½
Alt 0190 = ¾
If I do this setting and someone else opens my file, do they see these symbols?
If not, do they need to setup the same settings?
And if so, doesn't that make it cumbersome? (Especially if I send the files to a client.)
I don't mean to sound negative but the question needs to be asked.
Thanks in advance.
Rich
(BTW, didn't you see the symbols on the webpage...)
my first answer in this forum...
I have got altgr + 2. That's m². You need simplexn.shx for exampel.
Hope it helps. Lothar
I did see the symbols.
And your link did help.
Thanks!
Here's another star.
Rich
