How to write sheet events in Excel
Writing sheet events in Excel is very simple. Just right click in sheet tab and select view code. Select work sheet from objects section and apropriate event from the declarations section. Write necessary code. Thats all. You can do a lot with this feature. You can change the back ground color of cell with a single click in a cell or can change the back color when the value of cell falls with in a certain limit for a warning in your calculations.
