flash vessel, flash tank, flash steam, flash steam recovery
hello
i've been looking all over the internet to find out what it is to no avail. finally, i've stumbled upon this group.
please give me a short description on the above topics and most of all to the question 'what is flash'?
thnx a lot in advance.
adam
adam
RE: flash vessel, flash tank, flash steam, flash steam recovery
Flash is defined as a rapid vaporization achieved by passing a volatile liquid through continuously heated coils or by pressure reduction (vacuum).
Flash vessel = flash chamber = flash trap, mostly refer to an oil-and-gas flash separator operated under vacuum where the entering liquid flashes into it.
Flash drum is a facility such as a tower or column that receives the product of a preheater or heat exchanger to relieve pressure; volatile components are vaporized and separated (sometimes) for further fractionation.
Flash tank, a unit that is used in a processing operation to separate liquid and gas phases.
Flash steam is steam produced in a boiler (=generator) with hot tubes of small capacity designed to immediately convert small amounts of water to mostly superheated steam.
There are many connections with "steam", but I didn't find any on recovery of flash steam.
It may refer to the act of recovering flash steam from water-containing liquids.
This can be utilized for low pressure applications.
Download this for further details and design.
http://www.armstrong.be/pdf/N_101.pdf
Check also website of Spirax Sarco.
Flash means lowering of Boiling point due to decrease in system pressure, mostly used to produce steam by let down of condensate from high pressure to low pressure
