Sect I vs Sect VIII, Div. 1 application
Hi all,
I have used Sect VIII, Div. 1 and 2 for several years but I have never had to do any work that requires Sect I.
So I just wonder exactly for what kind of application or equipment must use Sect I. What is the definition of a "fired" vessel?
I know that vessels with a fire tube can be designed and registered with Sect VIII. This would be a free water knock out drum (which has a fire tube to heat up the oil for water separation). I think a steam boiler has to use Sect I. Is this about right? Any good clarification is appreciated.
Thanks.
Thanks.
RE: Sect I vs Sect VIII, Div. 1 application
a) Power boilers- a boiler in which steam or vapor is generated at a pressure of more than 15 psi for use external to itself
b)electric boiler- a power boiler or a high temperature water boiler in which the source of heat is electricity
c)minature boiler -see limits in PMB-2
d)high temperature water boiler- a waer boiler intended for operation at pressures in excess of 160 psi and/or temperaures in excess of 250F
This includes organic fluid vaporizers as well.
Unfired, waste heat boilers may be designed by either section I or VIII, but section I is less stringent.
