macro-izing solver in excel
I have a macro that runs several different solver equations in a sheet. after each solver solution i have to click 'okay' to keep the solver solution, then it continues on to the next equation in the macro. is there a command that will automatically select the okay button to keep the solver solution, so i don't have to manually select okay in between each solver run? just trying to save myself some time and make it easier for someone else to use the program. thanks in advance!
RE: macro-izing solver in excel
