Importing survey points
I'm trying to convert an ascii file to binary using "DTMTools Extract XYZ" in Geopak, so that a tin file can be plotted.
However, the ascii file contains too many points (>70,000), and there is a limitation to the number of points using "DTMTools Extract XYZ". Instead of dissecting the large file into small ones (Excel has a limitation of 65536 rows), does anyone know of any other efficient ways to deal with this problem?
Would ACAD do the task? Macro? MDL? AutoLISP?
Thanks for the advice.
RE: Importing survey points
I'm not sure about MicroStation, but in AutoCAD .... this is a simple task.
See Thread555-45632.
I hope that helps.
R.
Thanks! rKeytek.
That works well.
