HFA Settler Interface Level Measurement
I want to measure the interface levels in a Hydrofluoric acid settler. Due to the nature of HFA a non-contact measurement device is strongly preffered. So far the only non-contact solution that appears to be capable of measuring the various interface levels is a Vega nucleonic density measurement device. It produces a density profile of the vessel from which the interface between the HFA - Emulsion Layer - Hydrocarbons can clearly be seen. The trouble with this method is the obvious risk surrounding radioactive material and the high cost (£60k).
Can anyone suggest a alternative method or a nucleonic device that might be less expensive?
RE: HFA Settler Interface Level Measurement
Can you use a differential pressure measurement? Diaphragms are available in a variety of materials.
Ultrasonic can give you a contactless level, but I doubt you could get to the interface point.
Check out www.agar.com. They use microwave absorption techniques to determine oil/water interfaces. Perhaps they could suggest something.
Then, nuclear sounds like your only alternative. Yes, it's expensive and it's a hassle with the radioactive sources (and paperwork!), but it works well.
. . . Steve
www.towerscan.com
