Alternative material
Please can anybody help???
I am looking for a replacement material for an exsiting component.
The material I currently have is a BE Cu material with a yield of 110000 PSI and UTS of 140000 PSI I require a replacement material with the same properties and NACE complient. But also has to be fit for service in a high Mercury well environment.
Can Anybody offer me a solution on materials available
RE: Alternative material
http://www.specialmetals.com/products/publication/tech_bulletin_718.pdf
http://hgtech.com/Corrosion/Liquid%20Mercury%20Corrosion.htm
I understand that the better your finish the more resistant the material.
Also, is it possible to use a protective coating?
In the 1/2 hard condition has similar properties as 17-7Ph condition C. And is almost pure Ni, thus has great corrosion properties. Resistivity is roughly 4.3x10-5 ohm-cm. about 1/3 that of 17-7.
not sure about the Hg corrosion properties.
Nick
(ohyeah alloy 360 also performs well at elevated temps.)
you could try using inconel 925, which is good with mercury and Nace complient.
A good place to source is Special metals, who produce ignots, or for material suppliers try
HOWCO or Flange Fit.
hope this is of some sort of use
I would look at age hardening Ni alloy other than 718. Maybe 725 or even X-750.
I am not sure that alloys like 925 or a PH stainless will have enough corrosion resistance.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
