Torque
Torque
Hi, Engineering is not my field, so please be kind. I need to manually feel what winding a spring with 35-160 inch ounce torque feels like in order to complete a prototype. Is there a simple way to do this? Thanks so much. Lisa (toofarblonde@aol.com)
RE: Torque
Hope this helps but drop me a line at jralph@pslg.com if you require anything further.
RE: Torque
To give you an idea, your maximum torque of 160 in-oz will feel like picking up something that weighs about 10 lbs with your index finger and then flexing your finger at the first joint. Pretty tough, huh?! Assuming you are winding this spring closely around a stem (within maybe an inch or so of the stem), then you can expect to use about the same effort as would be required to open a pickle jar or other vacuum sealed jar. Pretty stiff for hand tightening, but easily do-able! The lower end of your scale will be very easy to gage. You should be able to spin that torque with little effort...kind of like the lid after the initial loosening is done.
RE: Torque
