Part modeling/modifying (v4.2.2)
New user here. I am learning part modeling in V4.2.2 and am getting confused as to no-show - yes swap. I have trouble understanding this whenever I do a modeling change to an existing model. I thought you could switch to 2-D and create new geometry that way. However, I am having problems doing this and have to go in the 3-D environment. Can anyone give me any tips as to how to modify an existing model? Thanks in advance.
RE: Part modeling/modifying (v4.2.2)
If there are any users out there who know of good listings and forums to v4 I'd like to know of them. The catiav5forum.de site is nice but it also has limited info on V4.
I just bought the Catia Reference Guide by Tigwell and can let you know if it's worth getting.
Good luck with adjusting to Catia, If you have Pro/E experience it's not too bad to learn but it's a lot harder than UG.
Michael
Show and No-Show is just a way to display or hide geometry. Most users will no-show construction elements (points, lines, surfaces) when they are working with a solid. But when modifying the solid, you probably want to re-display the construction elements you want to change.
2D and 3D really have nothing to do with SHOW/NOSHOW. 2D is just an easy way to create 3D elements that are in a 2D plane. These points/lines/curves can be modified in either 2D or 3D modes.
Tips on how to modify a model? I'd suggest you find someone you work with who is a little more experienced with CATIA, and use that person to mentor you through the learning curve. V4 can be a little difficult at first, but it will eventually make sense.
Here's some tips that might help:
To show everything:
click NS, yes swap, key *SPC, click EXIT
to hide everything except for solids:
click NS, key *SPC-*SOL, click EXIT
