dimensions disappear in SW2003
I just installed SW 2003 and in some parts when I dimension a solid the dim will appear for a split second when I place its location and then disappear. I'm wodering if it is a text color problem but everything is still set at default. Thanks for the help.
-todd
-todd
RE: dimensions disappear in SW2003
Check Annotations in the tree. Make sure it is checked.
Bradley
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.3dmca.com
FAQ731-376
When in doubt, always check the help
HTH,
Stefan
unofficial german SolidWorks helppage
http://solidworks.cad.de
Shareware, freeware, tools and macros
http://swtools.cad.de
Thats not true when your in a part sketch. I turned everything off:
Under Annotations in FM:
Display Annotations
Show Feature Dims
Show Reference Dims
Under View:
All Annotations I uncheked first then, Hide all Types.
And in a sketch these dims still show....Now that's the way I'm reading his post though...if He's adding reference dims after the sketch is made then yes your right "All Annotations" with the 2-3 checked Under the Annotations in the FM works.
Just wanted to clarify.
Best Regards,
Scott Baugh, CSWP
FAQ731-376
-todd
A
-todd
