VB code to run Excel dde
I have an Excel spreadsheet setup to record a machines downtime, faults,,,etc. What I would like to do now is have that Excel dde app. start and close automatically at the end of each shift. Is there anyone with a similar VB6 app that would be willing to share? I am an old PLC controls guy that is a newbie to VB. Any comments will be appreciated.
RE: VB code to run Excel dde
Sounds like you are looking for a sheet for each shift. If this is true that’s a lot of sheet. I would like to recommend using database programs instead of excel. Have you investigated this as an option? It seams to be easier and all your excel sheets would import. And the data would be much more manageable.
I did one that automatically closed the sheet and saved it as that day's date, then opened another sheet at MIDNIGHT.
Download the whole thing here:
http://www.mrplc.com/dl/index.php?action=view&view=entry&entryid=74
Here is the CODE:
Sub ChkTime()
Dim strFileName As String
Dim strNowDate As String
Dim lngMonth As Long
Dim lngDay As Long
Dim lngYear As Long
Dim strCharMonth1 As String
Dim strCharMonth2 As String
Dim strCharDay1 As String
Dim strCharDay2 As String
Dim strCharYear As String
Dim lngFileDateMonth As Long
Dim lngFileDateDay As Long
Dim lngFileDateYear As Long
Dim intCountMonth As Integer
Dim intCountDay As Integer
Dim intLoop1 As Integer
Dim intLoop2 As Integer
Dim intLoop3 As Integer
Dim strCurrentOpenedWorkBook As String
strCurrentOpenedWorkBook = ActiveWorkbook.Name
'extracts today's date as serial number
strNowDate = Now()
'converts serial number back to months
lngMonth = Month(strNowDate)
'converts serial number back to days
lngDay = Day(strNowDate)
'converts serial number back to years
lngYear = Year(strNowDate)
'assign a file name from date
strFileName = "M1138-" & lngMonth & "-" & lngDay & "-" & lngYear
    'don't check time if the file is not named by date format
    If strCurrentOpenedWorkBook <> "M1138.xls" Then
       'parse the existing file to current date (HEY What can I say! I liked my PARSER code!)
        For intLoop1 = 1 To Len(strCurrentOpenedWorkBook)
            If Mid$(strCurrentOpenedWorkBook, intLoop1, 1) = "-" Then
                    strCharMonth1 = Mid$(strCurrentOpenedWorkBook, intLoop1 + 1, 1)
                    strCharMonth2 = Mid$(strCurrentOpenedWorkBook, intLoop1 + 2, 1)
                    intLoop1 = intLoop1 + 1
                    Exit For
            End If
            Next
            For intLoop2 = intLoop1 To Len(strCurrentOpenedWorkBook)
                If Mid$(strCurrentOpenedWorkBook, intLoop2, 1) = "-" Then
                    strCharDay1 = Mid$(strCurrentOpenedWorkBook, intLoop2 + 1, 1)
                    strCharDay2 = Mid$(strCurrentOpenedWorkBook, intLoop2 + 2, 1)
                    intLoop2 = intLoop2 + 1
                    Exit For
                End If
            Next
            For intLoop3 = intLoop2 To Len(strCurrentOpenedWorkBook)
                If Mid$(strCurrentOpenedWorkBook, intLoop3, 1) = "-" Then
                    strCharYear = Mid$(strCurrentOpenedWorkBook, intLoop3 + 1, 4)
                    Exit For
                End If
            Next
            If strCharMonth2 = "-" Then
                lngFileDateMonth = strCharMonth1
            Else
                lngFileDateMonth = (strCharMonth1 * 10) + strCharMonth2
            End If
            If strCharDay2 = "-" Then
                lngFileDateDay = strCharDay1
            Else
                lngFileDateDay = (strCharDay1 * 10) + strCharDay2
            End If
            lngFileDateYear = strCharYear
        'compare existing file to today's date
        If lngFileDateYear < lngYear Or lngFileDateMonth < lngMonth Or _
        lngFileDateDay < lngDay Then
            'save file before close
            ActiveWorkbook.Save
            'select all data rows
            Rows("3:65500").Select
            'clear all data
            Selection.ClearContents
            'select a cell to get ready
            Range("A3").Select
            Range("INDATA!A3").Value = 3
            'save a new day under new file name
            ActiveWorkbook.SaveAs Filename:="C:\qsi\" & strFileName, FileFormat:= _
            xlNormal, Password:="", WriteResPassword:="", ReadOnlyRecommended:=False
            Application.Run Macro:="Auto"
        Else
            GoTo DateOk
        End If
    End If
DateOk:
End Sub
Chris Elston
Automation & Controls Engineer
Download Sample PLC Ladder Logic Code
at MrPLC.com
