Masonry Wall Design- Ig and Icr
I would be very grateful if someone could direct me to any websites which give information on the calculation of the Gross Moment of Inertia (Ig) of masonry units along with the calculation of the Cracked Moment of Inertia (Icr). I require this info for designing cmu walls using the Strength Design Method in accordance with UBC:1997.
Mike
Mike
RE: Masonry Wall Design- Ig and Icr
Ig = [b(kd)^3]/3+[b(h-kd)^3]/3+(n-1)As(d-kd)^2
For many of the variables think of a reinforced concrete section.
w/o steel: Ig = [bh^3]/12
For a cracked section:
Icr = [b(kd)^3]/3+(npbd)(d-kd)^2 where p is rho.
This information is found in Reinforced Masonry Design by Schneider and Dickey.
Thanks for the swift response and the info
Mike
