Pipe Pile End Plates
Is anyone aware of a guidance document that lists recommended thicknesses of end plates for close ended pipe piles as a function of the pile diameter?
RE: Pipe Pile End Plates
Hmmm, good question.  Have you seen what API recommends? (It may be in API RP2A.)  This is a common offshore issue.
You might re-post your question in the offshore engineering area Forum311 to see if you get more responses.
Good luck!
