Retaining wall design
I have a land with building.The back side land is fourteen feet vertical height and then sloping 45 degrees. The total length of the wall is 45 feet. Total height of the land is 26 feet(14 feet vertical and remaining 12 feet slopping and then level). can anyone suggest how to retain this land. I have 1000 cft rubble with me.Is it poossible to utilise this rubble for this work?
RE: Retaining wall design
First we need to know the soil profile, what you are supporting and what is the foundation soil. If you have no ability to excavate because of closeness to building foundations, you might consider shoring if drilling is possible.
A compentant geotechnical/civil engineer should be consulted and in charge of any attempts to retain the soil.
to stabalize the upper slope I would suggest a soil wrapping system using geotextiles.
This situation dose indicate the need for a geotechnical anaylsis and the solutions are numerous, but i wousl say using the rubble wouls be fine if the gradation is not excessive coasre (boulders, cobbels and such) and this type of retetion can use anything from sheet piles to concrete walls to block walls.
