Washer/Spacer Design
Am currently trying to design a spacer/washer to take a compressive load of 17.65MPa per unit area. The spacer is to be placed between 2 steel plates which rotate around 4 degrees relative to each other. It will be relatively thin - only 4mm. Corrosive environ also (sea spray).
What I would like to know, due to the dynamic conditions would I be on the right track looking at a brass alloy or a nylon plastic?
Thanks in advance
djw
Thanks in advance
djw
RE: Washer/Spacer Design
