shell manhole neck
shell manhole neck
shell manhole neck
The neck a 24" diameter manhole was fabricated by rolling and butt welding a steel plate. This was made in shop. Is it necessary to RX the joint to meet the API 650.
If so, where in that code does such requirement appear?
RE: shell manhole neck
See API 650 - 6.1.1: "Radiograph inspection is not required...welds in nozzle and manway necks made from plate..."
