Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It is good to know that there are groups such as this willing to share knowledge in this money driven economy..."
Geography
dunnlg (Mechanical)
19 Feb 03 14:36
If I have a .product & .drawing, then want to make a similar .product & .drawing, what method will allow me to “rename or save as new” each file, and force the .drawing link to agree? Am on R9SP4.
Thanks in Advance
ganeshn (Automotive)
19 Feb 03 16:35
using save management will help you to save the product file and its parts in a different location with links and/or with new file name. You can use the File>"Send To" option also to copy the product and parts at a new location with different name.
as far as drawing is concerned if u have renamed the product file then use Edit>Links>replace command to reestablish the link with other product file.
Else if the product name is same then just open the product to which u want the drawing to be linked and then open the drawing file. it will automatically establish the link with the opened product on saving.
Cheers
Ganesh.N
ganesh.n@engg.tjc.co.in
dunnlg (Mechanical)
20 Feb 03 9:33
I’ve tested the File>”save management” “save as” twice with excellent results with a paired set. Thank you. Now, can I also apply this to a mixed set? I’ve tried this same routine with unrelated .product and .drawing without success. When I open the “new/saved as” files in the new folder, the .drawing is still related to the original .product. At edit/links/pointed documents, the “find” option is grayed out. At edit/links I attempt to “replace”, select the file I want, open, and receive Incident Report Error, The link refused the document. At edit/links I attempt to “replace in session”, select the file I want, OK, and nothing happens. Is there a way around this? Also, I tried File>”Send To” with unrelated set, with the same results.
Sincerely,
Laura
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
