Vector Surge Protection for Generators
I require to calculate the torque applied to the rotor shaft, change in power, and change in rotor angle of a 46MVA 11kV 1500rpm salient pole synchronous generator for a 30deg vector shift in voltage while operating at full load.
Can anybody help?
Can anybody help?
RE: Vector Surge Protection for Generators
Yes I can help.
If it was part of your Masters research then I assume you've done dynamic studies on such. I don't have MATLAB or any other simulation software.
Is there a more simplistic or static approach to get in the ball park?
