Slurry pump seals
Slurry pump seals
All:
My experience with slurry pumps is zero… I’m getting ready to search the net for crash course info. If anyone knows some good links I would appreciate it.
The current problem:
Within the next several days or weeks I have to review some slurry pumps that are operating in series due to the head required. As I currently understand it the problem that has been experienced with the pumps so far is the seals or packing not lasting. At this time I don’t have much information and will probably repost in the next couple weeks. Any ideas of what to look for or possible solutions to consider while I’m collecting data would help.
The slurry pump manufacture will be at this meeting, so it is going to be a team sport… I just want a little insight before we get there.
Thanks!
Thanks!
RE: Slurry pump seals
I agree with macmil. Whether this is at Syncrude, Suncor or any other mining operation the same problem exists. Sealing an abrasive liquid is extremely difficult. The key solution is to provide sufficient clean water flush to keep the packing (or seal faces)cool and clean. In other words, if you can provide a flush at pressures above the pump stuffing box pressure (and in excess of the spikes indicated by macmil), you will overcome most of the problem. In effect, what is required is to actually have some flow of the flushing liquid into the pump housing.
The sealing problem is multiplied by the pumps installed in series and the resultant high differential pressure across the stuffing box.
macmil - Do you think Canadian Oil Sands Trust is a good investment since crude has reached US $37/barrel?
One reason I'm involved in this is because I provided the seal water system for the slurry pumps. The seal water is surface supply (clean) that I provide a dp up to 15 PSI for the last pump. With this customer I have a reasonable reputation because my close tolerance pumps work very well as long as the slurry pumps take care of the trash. I have numerous water pumps, pumping to the surface. These are definitely two different jobs!
There is quite a water history (if you would like some background from the 1980’s email me; some of it is funny), but to date we have offered them the best solution for water only.
Today I may have found them a solution to the current problem. I spoke to the customer today and gave him a couple ideas of reducing the need for the slurry's. I plan to see them within the next week or two so we can discuss further.
In-house stuff:
For a lack of better terms; “when dealing with oil wells available fluid in the well will come up the well bore.” With a mine as fluid increases it just goes out in the mine. You have no idea how much trouble it is to convince petroleum engineers that the TDH required is "X-FEET" with a comparatively infinite PI.
I do sincerely appreciate your input. Any other thoughts will most defiantly be considered and appreciated!
Thank you!!!
davidlsus@yahoo.com
About Canadian oil or any oil (my opnion.) I have not heard Presedent Bush use the word "if" when refering to Iraq. Stock in any oil company should go up at least for the short term. If Iraq lights their wells price will will go up and be stable for x amount of time. Be ready to sell quick, because Venezuela as well as the rest of OPEC will produce more to make short term gains. In my personal opinion OPEC is wanting about 20 to 25 dollars (US-WTI) as a bench mark.
The price of oil is already up! You may have missed your oppertunity for short term gains.
This is just my opinion.
mac
In my previous post re COS I should have included that the opinion expressed was purely personal, and that there is no intention to recommend the purchase or sale of any security. I am not registered or licensed to offer investment advice, and anyone considering any investments should perform their own due diligence.
mac
I own some too.
Okay- I wrote the following last week, but now that I’ve come back and read that you’re supplying the water support system for the plan 32… well- that follows the parenthesis.
(I’ll give you the lowdown about shaft sealing. First, choose a pump with a large bore stuffing box. This will make it so much easier to get a seal to work. More room for components, more area for cooling…
I know that several makers of ANSI sized pumps make a vortex generator that is part of the cast of the back-plate that really helps with slurries. Goulds calls it VPI and Flowserve- Durco calls it FML, I think.
If the OEM you like does not there are aftermarket vortex generators that can be installed, Sealmate comes to mind.
Slurry seals get a bad rap. They do. It can be done. If the solids concentration is about 10% or so look into the plain old elastomer bellows pusher seals with hard face materials, ex, John Crane Type 1, Flowserve Pac Seal… These work famously, a single spring won’t clog easily, the elastomer bellows holds up well in slurries too. If the solids content is higher there are two other types to look into, metal bellows seals, or the seals touted as slurry seals.
Metal bellows seals work well because the edges of the bellows “knife” through the solids, and windage is created around the bellows helping to increase flow around the seal as the bellows rotates. Metal bellows seals also have the advantage of a stationary secondary seal element. The o-ring doesn’t have to move, so no O-ring hang-up.
The seals promoted as slurry seals are generally made to work with the special stuffing boxes listed above. These designs generally use a stationary O-ring to wipe against the seal face to exclude solids from the springs that move this same seal face. The seals are made with a profile that tries to create a smooth flat profile around the faces to minimize the turbulence around the faces and reduce the chances that they’ll be abraded. This is partly why they are designed to work without a flush.
A Plan 32 Flush with a throat bushing is the easiest way to make a seal work in a slurry service. The flush rate is adjusted to cool the faces with clean fluid and to create enough pressure and flow through the stuffing box and the bushing to exclude the abrasives. Heck, the bushing is a plus if your bearings ever go to pot. Hard faces are a must; the solids can be crushed and spat out the atmospheric side. If you are really concerned, a Plan 62, or quench can be used to both cool the seal faces from the atmospheric side, and flush solids away from the faces.
If the solids are heavy enough and you want to try, a Plan 31 is the use of a cyclone separator off the discharge, with the clean fluid to the stuffing box, and the dirty fluid back to suction. These can be tricky, because they have to be “tuned”, the losses through the tubing have to be considered for these to work best. Cyclones can also plug and be a real pain in the keester.
I’ve just had really good experience with a double metal bellows seal in service at a Calcium Chloride unit. A Galagher pump with a stuffing box that used to be packed with aramid packing, a lantern ring, and what the other vendor called an excluder packing ring (just a solid teflon packing ring cut on a bias so it closes in on itself as you tighten the packing gland- a bushing). The pump pulls the “mud” from the bottom of a clarifier and sends it to a filter press. We installed this back to back metal bellows seal with a modified plan 52, or a 54, plant water piped in to the area between the seals at 20 or so pounds above the stuffing box pressure and back out to the sewer. This thing has run like a champ.)
Now for the rest-
What is the current configuration? If the water is clean I suppose the problem is keeping it at a constant pressure or at the pressure required to exclude the slurry from the stuffing box. Consider some kind of accumulator or N2 bottle system to boost the pressure with a regulator. I know that at least one company offers what looks like a reservoir, but has a disc and rod so that on one side of the disc the reservoir is at the discharge pressure, and the other side, due to the difference in area of the disc because of the rod (Pressure= Force/Area), is at some constant ratio higher. (check this link out- http://www.colossusgroup.com/products/zyg_english.htm )
If the pressure isn’t the issue, what is?
Josh
p.s.- Just remember that the Venezuelans are having their own problems with strikes and politics too. And even if they do get past those issues and boost production, Venezuelan crude is higher in Sulfur. More of that means more maintenance, more down time, and decreased profit margins.
Thank you for all the info. I actually printed this post for future reference.
The slurry problem was identified and repaired before I got there. That was good too, because I didn't have to look like an idiot!!!
FYI
I knew the seal water pump was not the problem; I designed it!
Thanks again!
This was a people thing. The slurry pump problem was identified and corrected before I got to the site. We had several other problems to deal with so this didn't bother me.
One of the engineers in my office has a bumper sticker on his car:
You just can't fix STUPID
I am still quite impressed with your post! Information plus...
