240 volt GFI protection
I need help wiring an electrical test station. This test station is used to test an commercial wet/dry vacuum system, in an industrial, production enviorement.
here's what i have;
i have 208 volts comming into my test box from a gfi breaker in the wall, (2 hots, a neutral, and a ground) a Staco, model #2520, Series Variable Transformer. I need this variable voltage control because we manufacture both 110vac and 220vac models. The problem lies here, because we test in a wet enviorment, i need to inexpensively GFI protect the operator. The Staco schematic only shows a the use of the 2 hots, where does the neutral go? Staco tech sup. says leave the neutral hanging, and the operator will still be protected, is this true? i have also seen these little pigtails with a gfi on them, but not in a 240 volt model will this work?....any sources on them? any help will be appreciated. thanks.
here's what i have;
RE: 240 volt GFI protection
If the supply is different from what I have assumed and you do in fact need the transformer, then you will still be protected by the upstream GFI breaker, as this operates on the principle of current balance between the phase and neutral leads. If there is a ground fault, some current will return to the source by the external ground path instead of via the circuit wiring - this unbalance is what the GFI reacts to.
so since i do need the the transformer, will i be safe by leaving the nuetral wire un-connected?....and one more related question, i have been told that, (by not that reliable of a source) that since i have a transformer between the breaker and the testbox. that the transformer in the test box is acting like a "new service". and anything downsteam of that transformer is NOT gfi protected?....sorry to be a pain, but production.
BUT PLEASE AS JBARTOS HAS SAID THIS REALLY SOUNDS LIKE YOU NEED TO GET A QUALIFIED AND REPUTABLE CONTRACTOR IN> he could set you up a system that is safe and easy to use for not much more than you will spend in your own time and labour. And you may save some after its done thru the ease of having a dedicated set up. - I put a star on Jbartos for saying it.
If you are concerned about different voltage ratings then contact your electrical wholesaler after all if you buy anything then you have to go to him.
Regards Don
