Designing of bi-directional clutch bearing
I need some help in designing a bi-directional clutch bearing.The chalange is to come up with a design which will be able to do the following:
1. act as a regular bearing with free rotation in clockwise and counterclock direction.
2. be able to run clockwise and lock counterclock wise. This can be done with a standard clutch bearing(needle bearing)
3. reverse the movement (run counterclockwise and lock clockwise)
4. lock completly.
If you know of any exsiting design please let me know.
4. lock completly.
RE: Designing of bi-directional clutch bearing
A fork shift mechanism may be able to switch functions like shifting gears in a stick shift transmission. It could be solenoid actuated.
