IS ULTIMET A HIGH $ ALLOY?
Looking at trying some Haynes ULTIMET cobalt alloy in wet phos acid production. This would be to replace Ferralium 255 (S32550). How does the cost of ULTIMET compare to other alloys, such as 316SS or 2205 (S32205 or S31803)? Are fabrication costs much different? Supposedly it doesn't gall as much as the high nickel alloys.
The UNS number for ULTIMET is R31233; it's composition is a nominal 53Co-26Cr-9Ni-3Fe-5Mo-2W.
RE: IS ULTIMET A HIGH $ ALLOY?
Nickel based common grade (Hastelloy X) $40-50
Cobalt based (haynes 188) $60-80
Most have large weight minimum orders due to rarity.
good luck.
nick
