Free Compilers??
Free Compilers??
Free Compilers??
i just started with C++ and i would like to know where i can get a free compiler that is easy to use.
RE: Free Compilers??
Go to bloodshed.net and download the DevC++ compiler.  It is easy to use and does a good job with console or Windows programs.
Steve
Go to the Borland site.  They have their latest version for free.  It is command driven and does not work with their IDE.
There is also a GNU C++ compiler available at http://www.delorie.com/djgpp/ or if you are learning C++, I recommend C++ For Dummies.  It is a good starter book and comes with a CD that contains GNU C++ and an IDE, which runs under DOS.
You should give a try to intel c++ compiler.
go to intel.com
It's not that hard to use it.
That's what I use
You could go to www.download.com and click under software developement.  They have a variety of compilers for download for C and other languages
