How to eliminate cells that are before 3:00 PM
I have a question regarding microsoft excel using Visual Basic.  I have a worksheet that has a list of activities sorted by "time" which is the first column, the other columns hold other information such as "company" and "name."  I want to delete the lines of information that happen before 3:00 PM.
The report looks like the following
TIME     COMPANY     NAME
7:00       TWP       Tony
8:30       CPI       Aaron
15:30      FGI       Frank
16:00      WTI       Anthony
How do I get rid of the two lines before 3pm using Visual Basic Code?
RE: How to eliminate cells that are before 3:00 PM
Try this:
Sub DeleteRow()
    Dim iRow As Integer
    iRow = 1
    While Cells(iRow, 1) <> ""
        If Cells(iRow, 1).Value < TimeSerial(15, 0, 0) Then
            Rows(iRow).Select
            Selection.Delete Shift:=xlUp
        Else: iRow = iRow + 1
        End If
    Wend
End Sub
