Beam End Forces Envelope
I'm looking for a faster way to get the beam end forces envelope for memebers. Currently I go into report setup and under range I manually type in each beam number that I want an end force envelope for. Is there a way graphically you can do this.
I noticed beam end forces can be done in the graphical environment, but can envelopes be done that way?
Thanks for all the help!
RE: Beam End Forces Envelope
If you double-click on the top-left corner, it'll select everything. Then, you can right-click, Copy and then paste unto Excel and continue massaging your data every which way you want. This can also be done automatically and seamlessly under the Open STAAD protocol.
