spi and rs232
spi and rs232
What's the easiest (and cheapest) way to communicate with a SLAVE spi device (cs5531 to be exact) via rs232? Any way this can be done without a microcontroller? Is it possible to connect two slave spi devices together (the MAX3110 sure looks good if this can be done).
And please let me know if this is the wrong forum (I'm quite new here).
TIA
c-tzar@c-tzar.com
TIA
c-tzar@c-tzar.com
RE: spi and rs232
RE: spi and rs232
RE: spi and rs232
More info = more help!
RE: spi and rs232
The easiest would probably be if you use a Maxim-Dallas 1-wire A/D converter like the DS2450 which has 4 channels at 16 bit resolution. Dallas does supply a device that you may plug into your serial com port on the PC to communicate with their 1-wire devices. The internet site of Maxim-Dallas is: www.maxim-ic.com
There is also appnotes available from them on how to do this if you are interested in building your own.
Beyers
RE: spi and rs232
The application is simply a loadcell (measures weight/force) hooked up to an A/D converter from which I want to read the raw counts (digital data) via the serial port on a PC. Loadcells put out voltages that typically range from 0-30mV at most so I'll need an A/D that's pretty sensitive and has flexible gain settings. I also want a differential inputs. Four channels would be nice but it not absolutely necessary. It would also be really nice to avoid surface mount, but if I can't, oh well, I can deal.
The CS5531/32/33/34 claims to be designed for this type of application and seems perfect for the job if only I could find an easy way to communicate with it.
The 1-wire to rs232 adaptor/DS2450 combo looks nice for some apps, but it just doesn't look like it will cut it for loadcells. It looks like the minimum full scale voltage for this chip is 1.60V and I'll probably never go over 30mV getting less than 20% of the full scale.
Any other chips out there sound like they might fit the bill?
RE: spi and rs232
Look at PC Data Acquisition Cards or something like the ADAM modules. Go to http://www.promicro.co.za/promicro.htm and go to their Industrial Automation Products where you will find a good idea of what is available.
