DRAWING MACRO
DRAWING MACRO
DRAWING MACRO
Just need a little jump start on this macro if anyone could help.
I need to create a new drawing using a specific template from a random part that I have open at the time. I would like to have 3 std. views and an iso. Also I would like to insert the volume of the part as a note in the drawing. I'm somewhat new to Solidworks API, but have worked with other VB code before.
RE: DRAWING MACRO
I am not sure you need a macro for this...
1) You may want to create a drawing template with predefined views (this will get you the 3 views and Iso view)
2) You can create note in the drawing template for the volume that is linked to a volume custom property in the model (this is a parametric note)
cheers,
Joseph
