I ve lost the icons of toolbars of CATIA
i installed the catia normally in my pc; and i could see all icons of tools; but when i reinstalled the same version with the same cd I can¨t see the icons; and see the full name of the command on the toolbar:
it might be by clicking on a option on the customize menu when the programs run right?
how can i load the icons?
RE: I ve lost the icons of toolbars of CATIA
just delete the files FrameConfig.CATSetting and the catia restar again like the first time.
Thanks to eklunja
Hi, I have same problem with CATIA V5R8.I tried to find FrameConfig.CATSetting files but not exist with this name.
Please be more detailed.
Thank you.
ok, the files are placed in:
C:\Documents and Settings\Administrador\CATSettings\FrameGeneral.CATSettings
C:\Documents and Settings\Administrador\Datos de programa\DassaultSystemes\CATSettings\FrameConfig.CATSettings
If you don´t have the files i can send you
excuse me! you should remove only the "FrameConfig.CATsettings" from C:\Documents and Settings\Administrador\Datos de programa\DassaultSystemes\CATSettings\FrameConfig.CATSettings
Strange, I have not : Datos de programa\DassaultSystemes\CATSettings\FrameConfig.CATSettings in the directory : \Documents and Settings\Administrador
Maybe depends of Windows? I use Windows 2000 Pro.
Thank you for your patience.
1)By default for Windows 2000 Professional CATIA stores setting files in following path :
C:\Documents and Settings\<USER Name>\Application Data\DassaultSystemes\CATSettings\FrameConfig.CATSettings
2)<USER Name> can be either Administrator or any other User.You can view Catsetting Files Only if You have Administrator Previlege.
3) By Default "Application Data " folder will be Hidden and You need to go to the <USER Name> folder ( in your case may Be ADMINSTRATOR) Go to Tools-> Folder Options -> View  and select " Show Hidden Files ".
4) You should Be able to Locate the CATsetting File Atleast by now.
Cheers
Shaks
Thank you. I will try.Instead that I find in Tool - Options a way to restore each icon but is boring stuff.
