PART VOLUME LINK
PART VOLUME LINK
I'm trying to link text in my drawing to display the volume of my part. Is there a way to do this?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: PART VOLUME LINK
IHTH,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.3dmca.com
FAQ731-376
When in doubt, always check the help
Create a design table in the model including the dimensions required for this calculation. Then add an additional column labeled $PRP@Volume with the appropriate calculation underneath.
You can add the note then as Scott stated above or insert the string $PRP:"Volume" directly into your note.
In several cases, I have also linked the dimensions from Sheet 1 of the design table to Sheet 2 (and more) for more complex calculations and then linked these results back to additional custom columns on the Sheet 1.
It makes for a very simple down presentation method to show how minor design changes affect the end product because the notes can be included in your model views in addition to you drawings.
One additional thing, if you use the additional sheets in your design table, be sure to go back to the Sheet 1 (you cannot rename this sheet also) before closing or SW will error out.
Good Luck....
Remember...
"If you don't use your head,
your going to have to use your feet."
File > Properties, click the custom tab.
Type 'Volume' (no quotes) in the "Name:" area.
Click in the "Value:" area to select it for input.
Click the "Mass Properties" button & select "Volume"
Click the "Add" button to finish.
Note that the units are set by the last settings you used under the "Options..." box in the Mass Properties dialogue.
Once you get your custom property defined, you can refer to it in notes or BOMs.
