Nonprintable cells in Excell?
Hi everybody!
I have a cell in my spreadsheet that I want to see during the work on it but not to print. What I must to do to hide it during the printing?
Zmei
Zmei
RE: Nonprintable cells in Excell?
I, personally, would use a Command Button macro but you could also do it manually to:
Set text colour to background colour in selected cell/s
Print sheet
Set text colour back to visible.
I think that should work! - - - bjt.
The easiest is if you had a whole column or row you want to hide when printing. This can be done by saving views. You can save a view with specific hidden rows and columns and print areas.
For single cells here is a way to get a non-printing cell (kind of) that doesn't have to be updated with a macro (I hate having to run macros to do things).
1. You will need a cell with the data you want to be able to see somewhere on a worksheet in the nonprint area - you could just do this, but then you have to always go find that cell instead of having it right where I assume you enter data and want someone to be able to see it easily (and not forget to check it).
2. Draw a control (text box is what I use) over the cell you want the data (use alt to snap to grid).
3. When you have the text box selected you should see =embed(something) in the formula bar. Make this point to the cell containing your value. (for some reason you can link it to a cell, but not enter a formula).
4. Click the right button so the pop up menu comes up and select format picture (the text box is now a picture). On the properties menu select move and resize with cells and unselect the print object.
In Excel, you can define a specific section of a sheet to be printable in Page Setup|Sheet|Print Area, and anything outside of that section is therefore not printed normally.
TTFN
If select an area, then remove a cell from the middle of it and set that area with a hole as the print area, excel will print it in four chuncks (left, right, above, below the cell) on separate pages.
Since you can operate on any cell anywhere on the sheet, couldn't you simply move the offending cell out of the print area?
TTFN
Most of the time if one of my checks went off, it meant the report wasn't going out, so I could make a cell on the report say Error or turn red (or both).
If you have checks, they should NOT be able to be overlooked, whether it is a tech or secretary or general data entry personnel, because at some point it will be you, the engineer, rushing to get a report out, doing it yourself instead of the regular personnel (who has of course become used to scrolling over and checking that little cell), and it is going to cause a problem.
