Carbon/Carbon Clutch
Hi
Does anyone know where I can find out about the marerial used in carbon/carbon clutches ?
RE: Carbon/Carbon Clutch
Cheers
Greg Locock
Mike
You are aware that F1 clutches are multiplate jobbies, like a motorbike, not a single plate design?
Cheers
Greg Locock
Cheers
Greg Locock
Therefore my “expert” guess will be that you should search for some carbon/carbon composite manufacturers and bug them.
Thank You for all the supplies, however, I have had a look at all the options, I am so far unable to locate any carbon/carbon manufacturers, If anyone know who manufactures this, it would be a great help.
Companies like Unasco Shamban or Garlock spring to mind
pat
http://www.sgl-hitco.com/products/temperature/carbcarb/
http://www.snecma-propulsion-solide.com/en/presentation/programme_industrie/presentation/index.htm
http://www.ballard.com/tD.asp?pgid=82&dbid=0
http://www.chemnet.com/dir/United_States/Carbon_products/
This really helped me out :)
I did some more research, and the material I am looking for is called Carbonite, does anyone know who manufactures this?
