Cones w/ Half-angles >30 deg.
In Section VIII, Div. 1, what formula(s) do you use to calculate the required thickness for a concentric cone with a half-angle > 30 degrees?
Thanks!
-Christine
Thanks!
-Christine
RE: Cones w/ Half-angles >30 deg.
refer you to the formulas in UG-34 (ref. 1995 ASME
Sec 8 Div 1 Code Book).
prex
http://www.xcalcs.com
Online tools for structural design
Suggestions:
1.Remember anything you get off of this site is only an opinion.
2.Use current Code Books.
3.Look at the courses offered by ASME and National Board.
4.Run all questions and rough drafts past your AI. He/she
should help or will find someone who can.
5.Learn from your problems.
6.When looking something up in the Code,read the entire paragraph.
7.Have fun.
