Prefabricated Outdoor Enclosure
I am currently setting up a remote booster pump station.  The booster pump is going to sit on a small concrete pad (approximately 4'x2.5'), and I need a weatherproof enclosure to cover the pump.  I'm trying to stay within budget, and I figure that a prefabricated enclosure would be cheaper than one that is custom built.  Does anyone know of such an enclosure and where I can find one?
Thanks for the help.
RE: Prefabricated Outdoor Enclosure
Home Depot
Sears
Are you serious?  I practically live in Home Depot, and I don't ever remember seeing any enclosures....but then I am usually in the lumber or tools section.  I'll check it out, but I don't know????
Try www.powerdesigninc.com
The build pad mounted enclosures of about the size you are looking for.
Hey thanks for the links.  Powerdesign inc had some applicable products but they were a little pricey and a little too big.  I found several other manufacturers (Arkfeld and MekCo) on Thomas Register, and I think I may go with one of them.
